Hello all. I'm new to this forum. Thanks in advance for any help. I have a Troy Bilt riding mower TB30R. The B&S engine is 21R7070039G1. Power Built 10.5 gross HP 344 cc. The mower is a 2015. Here is what happened. My son tried to start the mower last week and the starter engaged but wouldn't spin. I thought I needed a starter, so I ordered one and installed it. Still would not spin. I did notice that there was a gas leak from the carburetor area. Could not identify where it was coming from. I removed the spark plug, and fuel (with an oily film) poured out. I cranked the engine, and of course it spun easily. It was Hydro locked. Spinning the engine pushed all the fluid out of the engine. Put the plug back in and it started. Lots of white (maybe blue) smoke. It ran for about 20 seconds and died. It did restart, again with lots of smoke and then died again. Ordered a new carb and installed it. It was hydro locked again, so I removed the plug to clear the fluid. Put in the plug and it started. The smoke was there for only a few seconds and then it went away. After about 20 seconds, the smoke came back and the engine died. I could start it again, but there was still smoke, and the engine died within 10 seconds. I pulled the oil dipstick and the 'oil' was very thin and had a strong gasoline smell. My guess is a cracked block or head. I'm not sure how the guts of these engines work, so forgive me if i got the terminology wrong. Can it be fixed? Do I need a new engine? Maybe a block? Thanks again.
