I Need a air filter for a Vintage 8hp Briggs rear engine snapper rider
jeep534
  • / I Need a air filter for a Vintage 8hp Briggs rear engine snapper rider
I am in need of a air filter for my mower
model 280686 s/n 7361 7783
briggs model 190702 type 2190 01 code 88121 109
no idea what type and year thi mower is.
Happy Hunting
archie
Three different filters were used n that engine. Do a google search each of these numbers to see which one looks like yours. 270251, 496047, 270579
Most likely your mower is a 1989 model if it still has the original engine as the engine was built Dec 11, 1988.
jeep534
Guys thank you ... it is the 270251 however i need the metal parts and bolts as well
Scrubcadet10
Moderator
Staff member
This should be it, air cleaner and parts, top right in diagram
jeep534
Scrubcadet10
I apreciate the link however the part I need is un available
Happy Hunting
If you spend a little time checking out your local repair shops I’m sure you can find those parts. Might need to clean and repaint them, but there are plenty out there.
Double ditto again.
I must have at least 5 of them in my stash & I have only been serviceing mowers for a short while.
The trick is to find a repair workshop , one that only repairs old mowers & sells used ones .
If the place a big plate glass windows & 3 smiling salesmen running around you are in the wrong place.
Down here you find them in residential areas, usually trading out of their double garage, with a triple car port in front of it. .
Print out the parts tree page and take it with you
jeep534
All the repair shops I have found here don't have such an animal. I have rolled a bunch of miles looking for one. The last guy an amish man said he had never worked on a snapper
Berts mobil, Would you be willing to sell me one out of your stash. I am not worried about the condition this is a deily driver machine
Thank You
archie
P.S. I am in WV
I reside in Australia so postage from here will be a little on the excessive side.
The air filter is not unique to Snappers as we never got them down here.
