Need some advice please. I rushed into my Ariens Max Zoom Transaxle Oil change without reading the manual, big mistake.
I removed a plate underneath thinking it was a drain plug and I think but am not sure that I drained all the oil from the internal pump.
The other side I did properly. When I refilled with oil, the side that I messed up now has no drive.
Please can someone who understands this tell me if that is the case and if so, how can I refill the internal pump with oil, I'm thinking turn unit upside down and pour oil into the same plate I removed. But this time I'd rather ask for advice first.
Thanks in advance
Thanks in advance
