I have a z525e 40hrs won’t pull gas
Oaks
I have a z525e 40hrs replaced Fuel filter, air filter, fuel pump, spark plugs and clean carburetor. It seems as it’s still not pulling gas to the carburetor. Previously drained tank and added new fuel no ethanol. Thought?
Scrubcadet10
Moderator
Staff member
Fuel line not clogged? Can you blow air through it?
As Scrub said you must verify that fuel is getting from the tank to the pump. Remove the fuel line at the pump and with the. fuel cap off, blow through the line while listening for air bubbling in the tank. If you hear air in the tank, have an assistant hold the line in a glass jar and blow into the tank. You should see fuel entering the jar and continue until it is half full. Examine the fuel for debris or water settling on the bottom. Install line try starting and report back the res and all engine numbers.
