I bought a used LT 1000 21.0 hp 42 inch mower. At the time I did not realize that the draw bar back plate was missing. Just to give you an idea,,with the draw bar missing you can see
the transmission pulley with belt. The problem is that if you try to press down on the clutch/break all the way while mowing, it throws the belt off the transmission pulley. By playing with the
pressure to apply to the clutch/break I can keep the belt from coming off just by barely engaging it to stop and to shift to another gear. What I want to know is that if I buy the draw bar and put it on,
will that stop the belt from coming off the pulley? i have looked for repair manuals for this mower, but I guess they don't exist outside the Sears repair world. I have the owners manual,,,but what I need
is a repair manual. Does anyone have any information about what I seek here?
