TrayWay143
- Feb 27, 2023
- 4
- 13
I want it to be used as a riding toy but when i rewired everything it will crank but will not try to start
As for the fuel solenoid on the carburetor it does power all the time when cranking and running.It has spark and would there still be a way for them to be activated if the wire harness is completely taken out?
Also the bowl on the carb does that need to have power all the time?
hope this helps the 2 red wire toggle is momentary.I want it to be used as a riding toy but when i rewired everything it will crank but will not try to start
The carburetor anti backfire solenoid going bad happens more than you think. I repaired them my way last year several times. Even when they are working, they can be intermittent and cause problems.hope this helps the 2 red wire toggle is momentary.
Run kill wire from eng to toggle thats grounded on dash. Use only starter solendoid and ign switch or push button to start. simple and usable as toy.I want it to be used as a riding toy but when i rewired everything it will crank but will not try to start
