i bought a new used bobcat it wont start/run
bryanstophel80
hi i bought a new used skid steer and i cant get it to start run i have oparted skids before no problem it keeps say wrong start code i am use the code they give me i cant even load it to take to bobcat
please help job is a must finsh on time
sgkent
call the people who gave you the code and tell them it is the wrong code.
Take the battery terminals off leave it 1/2 hour then replace them
If the ignition refuses the code then use the service code.
Usually the service code can be used to programme in a new start code
On all of the ones I have worked on the service code was initated by turning the key on & off a specific number of times
There are a lot of different modules so you might need to call Bobcat to get the appropriate recoding instruction but you must have the machine details first .
sgkent
he needs to call the people he rented it from, or his boss with the problem, or as far as I am concerned it is stolen.
