Hello,
Working on a Ryobi # 80544 with a R210III 212cc engine.
I can only pull the starter rope on every like 4th try - its stuck on the other 3 times i try to pull it. So ii I take out the spark plug and pull the rope, no problem it rotates easily. I was expecting to see either oil or gas coming out of the exhaust or spark plug hole but nothing came out. If I look into the hole of the plug i can see the piston and it is dry. I can see gas near the choke on the carb - looks wet.
I'm not sure what the source of the problem could be. Before this happened I took the head off to inspect for a "no-start" problem - but I was always able to pull the rope then. I made sure I was at TDC and I set the correct valve lash.
Any direction is appreciated.
Robert
Robert
