I've got a 2006 Silver Eagle 2550 and after mowing about 30 min. the right side pump starts to loose power. The fluids and filters are new belts are also new. Service was done at the DC dealer. I had a John Deere hydro that would do this and the pump was worn, Is this a common problem and can I get a kit to rebuild the pump? The Dealer is not really a viable option as they messed this one up once before. They had replaced a coil for running problem for the previous owner but could not get the coil to fire. after 6mo. of trying all kinds of new parts. the owner pulled the mower from them and sold it to me for 500.00. then bought a different make of mower. The dealer installed the coil upside down causing it to ground out, took 30 min. to figure out. Previous owner said there was never a problem with the pumps before this. I'm a mechanic with 35 years exp. so rebuilding the pump is not a problem if I can get parts. Thanks
