hydro-gear zt-3100
jlt
Does anyone have a hydro-gear parts diagram(with part #'s) for model # zl gpee 3k5a 1fxx? I need the part # for the input shaft pulley. The people at hydro-gear don't seem to know which of the 4 different pulleys go to this hydro. Mine is a flat 4 1/2", made onto the splined hub. They think it should be a cupped pulley with separate hub. The one I have is original(year mfg. 2008). Thanks in advance.
I think you are caught in the pulley/fan standardization which they went from a one piece pulley with splined hub to a separate pulley and hub configuration. You may need the 71833 pulley/fan/hub kit to fix the issue.
