gregjo1948
- Nov 28, 2012
- 75
- 361
Working on a Hydro-Gear transaxle---ZJ-KMFE-3B5C-1PLX. Is there a rebuild kit for it? Where could I get a new one? thanks, gregjo1948
No. Most ZTRs uses separate transaxles.does the transmission have a differential? If so you may need to block one wheel to get the other to drive. A differential transfers power to the wheel that spins the most free unless it is a limited slip. I've seen mechanics forget that, put a car on a lift and wonder why the wheels slowly turn in opposite directions etc..
Yes with the wheel(s) off the ground work the lap bar(s) back and forth to purge the air from the system.Got the transaxle back together and mounted on the Ferris. It doesn't turn the wheel. Everything looked fine inside and I think the only problem was an oil leak which I fixed with the seal kit that I installed. Any ideas why the wheel isn't turning, would be appreciated. I found online that it uses 20W50 oil which I installed. Seems like heavy oil for hydro. Is it supposed to be blead somehow? thanks, gregjo1948
