Hydraulic oil & filter change after first year or not?
bladedoctor
  • / Hydraulic oil & filter change after first year or not?
Hello, all. Hope everyone here is doing OK. Another question for the experts. My Hustler Raptor SD 60" mower is one year old. And, I have put a whopping 21 hours on it. I read in the owners manual that the hydraulic fluid and filter should be changes after 75 hours of use or after the 1st year of use, which ever comes first. With only 21 hours on the meter, should I go ahead and change the oil & filter? Or, can it wait a while? I haven't needed to add any fluid yet. Thanks for any input.
cpurvis
I think what they're saying is the hours don't really matter that much unless you run it more than 75 hours in the first year, in which you'd change it before the first year ended. One year or 75 hours, whichever comes first.
I'd change it.
Change any new fluid on any new engine slash mower. People spend thousands on a mower and neglect a simple fluid dump. Then wonder why it breaks down in peak mowing season. Mower shops are slammed from May to October.
bladedoctor
Thanks for your reply guys. Looks like I'll be getting some oil on my fingers this weekend. I know that I should raise the rear end and put it on a couple of jack stands. Do the rear tires have to come off? Or, does that just make it easier to change the oil and filter? The general service manual and the owners manual are fairly clear about how to do the change and the purge afterwords. But, has anyone here posted their step by step directions as to how they do this? After I do this once, it will probably be easy the next time. Just want to avoid stupid mistakes the first time. Never mind my questions. I've seen the YouTube videos
mmoffitt
THEN FOLLOW IT..it's right from the horse's mouth(manufacturer)
bladedoctor
Well, I changed the fluids and filters yesterday. I think it was much easier with the rear wheels off. The top port plugs were a PITA, but doable. Should be good for another year. Thanks for those who replied.
cpurvis
You should be good for several seasons now, at your current rate of usage. I think mine went from first year to 200 hours to 500 hour intervals.
tpack
I did mine today for the first time . It is 3 years old with 104 hours on it.
The hydraulic oil for the Hydro Gear Transmission 2800, 3100 or 5400 should be changed after the first 75 hours of use, then every 400 hours after that. However, the oil can be changed at any time, especially if the performance of the hydrostatic drive is reduced. Note that the hydraulic filter needs to be changed at the same time (if equipped).
cruzenmike
It is surprising that they recommended after the first year. Everything that I have seen in manuals states after xxx hours AND then every year after. You should have been able to wait until 75 and did it for the first time then. The reason why it goes to every year after the first is because with each opening of the hydraulic oil system there is always a risk of introducing contamination and therefore filter and oil changes each year keep the system running optimally.
cpurvis
Not like that with the 3100's I have. They recommend an early change, then a 200 hour change, and longer intervals (not annually) after that. I think it's 400 hrs.
