As I am about to start my spring prep work on my mower I am seeking advice on two problems I endured last year and hope to fix before this mowing season:
1) One of the front tires will not stay inflated. Is it okay to "slime" it or should I just take it to the tire repair shop?
2) Every spring for the first 3-4 times I mow, the grass clumps up under the deck and I have to stop every so often (to the point it is annoying) to get down on the ground and pull all of the clumped up grass from underneath the deck. The lawn is NOT wet. Anyway to correct this?
thanks everyone.
thanks everyone.
