Hustler Raptor 933077 Fan/Pulley Kit
Evans35173
Anyone have any instructions on how to change the fan/pulley kits on a Hustler Raptor 9330477, 52" deck.
BlazNT
YouTube search for fan pulley kit 9330477 watch the video. He says you need an impact wrench.
Evans35173
I've watched that youtube video and it's not the same mower. Thanks though!
BlazNT
I looked up what drives you have and they are relatively easy to work on. Depending on weather you are changing one or both makes it a little different.
1. Jack up mower so both rear wheels are off ground.
2. Remove wheel/wheels for pulley replacement.
3. Remove drive belt from pulleys.
4. Remove parking brake. I remove the screw that connects it to the trans.
5. Remove drive linkage.
6. Remove 6 mounting bolts. Trans will come out.
7. Remove nut holding fan and pulley on.
8. Remove fan and pulley.
Reverse instructions for reassemble.
Evans35173
Thanks for the info. My parts should be in today or tomorrow. I'll print these instructions out and pass them on to my husband. I really appreciate your help!
GaryDavid
If the pulley is good and just the fan is damaged how important is it to replace the fan? Doesn’t seem like it really does much at all.
Very important it cools the hydro.
Also the Fan/Pulley Lock Nut is torqued to 540-660 lb-in [61-75 Nm] (45-55 ft-lbs).
