Hustler Raptor 54SD LEFT HYDRO TRANSMISSION
beebem97
Left hydro transmission slips then once it cools down it pulls again. Any ideas?
Either the hydro is on its way out or the belt is worn too much & is slipping
The left hydros always go before the right because the belt slips so the left is always running that tiny bit slower.
Ao top of that the left side seems to accumulate far more dust & debris than the right so overheats .
Changing the oil & filter may extend the life a bit but do the cheap & easy bit first by fitting a new belt
beebem97
Hydros replaced twice under warranty. Right bracket broke so I lost the belt. Put on the new service kit and new belt. I also did a complete fluid and filter change and purged all air from the system. Now left hydro will not drive when it gets hot. At this point I am extremely upset with Hustler that they did not have the dealer install the new service kit when they had them replace the Hydro transmissions. I definitely feel like there should’ve been a recall and the fact that it is not is negligence on their part.
Well this is a bit different to the original post
Try more purging on the left side
It s very important to purge at the lowest speed you can run the engine.
This prevents the oil foaming thus removes the oil better .
I have taken several days some times to fully purge a hydro
beebem97
Will do. I do purge on the lowest speed possible. How do you purge one side separately?
only move the left stick
and don't forgrt to start with the wheels off the ground and the bypass open .
beebem97
Ok….I have replaced the belt, all of the brackets and hardware, and serviced both hydros. I have purged the air multiple times. This thing keeps throwing the drive belt. I am at a complete loss as to what to do. I have to believe one or both hydros are going bad.
The mower throws a belt because the pulleys are out of alignment, the belt is router wrong, the tensioner is in the wrong place or spring is too weak or there is something stuck in one of the pulleys
On Hydros you can add a bent fan blade
clubairth
Does your Raptor have the proper undated Hydro braces installed? Sounds like it does not since your throwing the belt?
These need to be installed on any Raptor and check the bolts to make sure they are tight too. Braces have cracked and bolts have fallen out before.
BEYTILL
AND…….Install the bolts the RIGHT WAY!
