Mad_mat222
- Jul 12, 2019
- 16
- 63
The drive belt on the raptor SD keeps throwing. I clipped a post the other day and it spat the belt immediately. Up until that point and after 290hrs, I have only had the belt come off once and that was when it wore out and snapped.
There does not appear to be any damage to the Hydro drive (port side). I put the belt on 3 times and it spat it within 20m each time and on the 3rd snapped.
I replaced the belt and idler spring and it seems to be going alright since (about 2hrs mow time) but did jump off when I drove off a kirb.
the idler has minimal play and in good condition. The idler arm does have some wear and I adjusted the nylon nut to the point slack was taken out but the arm could still move freely.
the pulleys on the drive appear in good condition. Nil damages fins etc.
my guess is that the idler arm was probably the cause. Any suggestions or experiences
interesting that I have had a few gremlins starting all around the 280hr mark. Until then I didn’t have an issue. Multiple issues since.
