Hustler Fastrak Wheel Motor Oil Leak
Windy
Hello
Left Wheel motor leaking 1 oz oil from axle shaft per mowing hour. Otherwise pump works great. Question is will a pump-motor seal kit repair the problem or should other things be looked at during tear down.
Hydro gear pump motor
Model 788067
Type 311-2600L
5173220022
approx 200 hours homeowner use.
Thank
noma
Hi Here is a web site to find your Hydro Gear Pump Motor click on site and then click on dude with the hand and it said click here for complete parts menu , then go toXXX-2500 then put in your model number 788067and it will show a diagram of your pump Lawn Mower Parts and more Outdoor Distributors - Lawn Mower Parts and this should work for you .
Windy
Thanks for the help.
