Hustler Fastrak transmission issue
Lmcneese
Can’t get the hydro to work since I replaced seal, fluid and filter. I’ve done the purging process. It leaked last season, I just kept oil in it. It sat all winter with the fluid leaked out. Could the hydro be bad now?
Jimmy O
Mine would not work after oil change but i figured out i had gotten the transmission charge pump cover on wrong. If you took that cover off, Gotta put it on same way it came off . Turned it 180 degrees and to my surprise it started working .
