Could possibly be the hydraulic's ?......but do the quick simple check first....check the tire(s) to make sure that it has the proper air pressure or does not have a slow leak, etc. before actually tearing into the hydraulics?
Hopefully something that simple will correct the problem?
If not, good luck on determining the outcome and getting it fixed.
