Hustler 3400 outfront deck
Ray18
Hi I have just acquired a Huslter 3400 72" deck and the deck belt has snapped I have
managed to get the part but no diagram for fitting, the model No is 925529 I was given
a link to some manuals on this site but the model number was not on there can anyone
please help its the one with the cab if that helps
Thankyou
Mr. Mower
First off is the deck on your mower have a "side discharge" or a "rear discharge"? (don't really know if that makes a difference or not).
Either way there should be a decal somewhere on the mower showing the exact outline route of the belt so look real good around the mower sides, top of deck, etc. for it.
If not then click on this PDF and go to pages 4-2 & 4-3 and closely follow the belt outline of each to guide you.
https://www.hustlerturf.com/file/109631CE_EN.pdf
Also, don't know if just by chance your mowers deck might require two belts instead of just one because after all it is a 72" deck?
If so then click on the next PDF and scroll down to page 4-3 and it shows a diagram of both belts and the route needed for each.
https://www.hustlerturf.com/file/025627_0600.pdf
Anyway hopefully this will at least help you or get you started.
If you are still not sure or want an exact diagram, then I'd suggest that you contact Hustler Corp. directly and inquire to speak with one of their engineers.
Just my $0.02
Good Luck!
