Husqvarna YTH22v46 Starts, Cuts, Then Won't Restart Until The Next Day
ATGV
  • / Husqvarna YTH22v46 Starts, Cuts, Then Won't Restart Until The Next Day
I have a Husqvarna YTH22v46. I start it up fine, cut my front lawn (about 25 minutes), turn it off so I can open my gate and cut the back yard, and it won't start up again. I then have to let it sit overnight, to which it starts right up in the morning. However, if I shut it off, same thing happens, I have to let it sit overnight before it will restart. Could this be a battery, or some sort of sensor issue?
Cranks but does not start at all
Won't crank at all
Fires a couple of times but won't stay running
ATGV
Won't crank at all
It cranks, but won't fire up. If I keep trying, the crank eventually gets weaker and weaker until its basically dead.
Recharge the battery .
Get a can of carb cleaner and go mow
when it won't restart squirt a SMALL amount of carb cleaner down the carb and see if it fires
You should not need to turn the mower off to open a gate
When the parking brake is set you should be able to get off & leave the engine running, provided that the blades are off .
Not a fix but a work around till we figure out what your problem is .
ATGV
Thanks for the advice, I will give this a try and let you know how it goes.
Reported multiple threads as spam
