Husqvarna transmission fluid type?
jsirmg
Replacing seals on RS800 CVT axles and want to top off the fluid. What type of fluid does it take?
Thanks, Happy Thanksgiving
It EP2 grease but before you try take the mower out and drive it around for 30 minutes and then feel the bottom of the transaxle if only warm don't worry about it per General Transmissions. Most times it look a lot worst than it is.
Here's an example didn't need grease added.
Beside to add grease you going need to pull the transaxle.
jsirmg
Thanks for the information. Happy Thanksgiving
Per your other thread the grease is EP 00 and not EP2. Sorry for my mistake as it appeared to be EP2 here.
