Husqvarna self propelled
Lojo91
Hi. I have a Husqvarna self propelled.... upon initial start up for this season, it started, but was chugging, then stopped... then I flooded it priming it... waited it started, same thing.. restarted and while working the throttle-- it seemed like it needed more gas-- and when I tried to "rev her up" that killed her immediately. Changed the spark plug, checked gas line, all seemed fine... Started right up, but chugging... like a miss, exactly the same as before but would run, roughly at idle... Again, gave it some gas and she stalled. What do you think this could be?
tomsteve
did you store it at the end of last season with gas in it? if it has last seasons gas in it, drain it out and put in fresh gas.
