Husqvarna rider 16
yelrow
Hi, recently added new throttle cable, (never again), what a fiddle. Works fine, but speed has been reduced. Flooring the pedal, is limited to travel. How can i get my speed back. thanks.
Please post all engine numbers, so we can see what you have. It would also help if you posted a pic of how the throttle cable is attached to the engine.
Cable is not clamped in the correct position.
Yes it is a fun job
Bert is probably right, I just want to see his setup and engine to tell him how to fix it.
yelrow
hi, engine number 28H707 1291-E1 00041720. Cable is attached at rear under transmission cover, the one held with 2 screws that houses gear box oil filler , etc. Cable is attached at front to acccel pedal. .When you hold down pedal, there does not appear to be any more to have, as Engine lever is fully deployed. I cannot pull it up any further. I am 77 and disabled, so not easy.. Machine does not go as fast as it did on old cable, and when you drive, foot pedal is fully depressed. Ideas please. john
yelrow
I have a picture on my ipad, that i can post, if that would help.
Let’s take a step back, because I’m confused. Are we talking about engine speed or ground speed? Makes a big difference as to how we proceed. If it is ground speed, we will need units model and serial numbers. Pics will be helpful either way.
yelrow
Hi, its ground speed. To my mind the old cable allowed the mower to ride quicker. I have a john deere, which is much faster. I want machine to cover the ground faster. Husqvarna Rider 16H. Engine number, you have. Motor, briggs, 28N707. What else do you need.
So the cable you replaced was the transmission cable to the hydro not the throttle cable to the engine
yelrow
Year 2000 chassis no , may be 531005017
