Chattanooga_Chuck
- Sep 30, 2017
- 1
- 4
I am stumped and really need some input here. I have a Husqvarna LGT2654 with Briggs Model 445877 Type 0760 E1 Code 071019Y6 Lawn tractor. Last week my wife cranked it and pulled it about 5 yards then turned it around to get lined up with where she was going to mow. I walked over to ask her something and we were talking and it shut off. Has not run since. It cranks but will not run. It was run the day before for about 2 hours and it was run that morning for around 30 minutes. Then after lunch the above happened.
Here is what I have done to date.
Changed both plugs
Changed fuel filter
Changed air filter
Drained and put fresh gas in
Took carb off and was able to access most everything so I did a thorough cleaning of the carb but couldn't remove the bulb at the bottom so I was unable to get to the jet to clean it.
Tested the kill wire
Tested the seat switch
Checked all wiring and couldn't find any issues
It does run if I spray starter fluid but dies.
Engine sounds good.
I think I have listed everything. So what am I missing.
Changed both plugs
Changed fuel filter
Changed air filter
Engine sounds good.
