Husqvarna LGT 2654 960450047 Electrical Issue
Psjr57
Hello, I have replaced the battery, seat switch, solenoid, ignition switch, blade switch. I tested the solenoid and i5 is working. My problem is that the tractor will not crank immediately, I will sit there and turn the switch off and on and it will turn over and start. I can turn it off and it won’t start again if left alone for 20 mins or so again with no crank. And once again it will turn over if I mess with the key once agin. This is frustrating. Thank You
Could be a bad electrical connection on the battery negative cable where it connects to the frame. Also could be a not fitting properly or corroded electric terminal at any of those switch locations. Some of those setups have a spring tab in the center of the electrical terminal that will break off and will cause intermittent contact.
