Husqvarna Lawn Tractor YTH20k46 - Runs but won't move after tire change
Joemf88
  • / Husqvarna Lawn Tractor YTH20k46 - Runs but won't move after tire change
Hey fellas, new to the forum here.
So I ended up trying to fix the tires by standing the lawn mower vertically on its nose and back. I know it was wrong but that is all I could think of doing at the time. Well when I laid the mower back to its normal position I wasn't able to make it move anymore.The engine runs fine. There is tension (Not as much as it usually does) on the forward and reverse pedal. I followed the rod that links to the trans and it seems connected but maybe I was missing something. I couldn't see very much.
Is there something that I am missing here? Any information would be greatly appreciated.
Thanks,
- Joe
Did you remove one of the rear wheels? IF so then you may have lost the axle key.
keakar
check the release rod wasnt jolted, you may have the trannny in bypass mode
