Husqvarna 25 Micron filter 522805401
TwoDocs
I need a OEM Husqvarna hydraulic filter part, 522805401 25 micron filter. Husqvarna is on backorder until pigs fly apparently. Does anyone have this filter on the shelf? Thanks.
Tiger Small Engine
Try looking up filter on oil filter cross reference sites online. There are normally several good substitute filters that will work.
Don't have or needed the filter here but if it a 1 inch-12 threaded mounting hole you could check the Lenz CP-752-30 filter at Tractor Supply provide there enough clearance for it.
Found I can the 522805401 has been on back order for over a year now. Husqvarna in general is getting to where things are on back order a lot. Just got a seat after it was on order for nearly 3 months.
