husquvarna transaxle
gobbles4
on my last post i ask if it is normal for the transaxle to leak the oil from the transaxle because i over filled it. After i mow and then park the mower in the garage the next time i mow there will be a oil leak on the floor and it is not coming from the engine and it is not leaking from the filters.
Normally they do not blow seals but will leak from the breather on top of the trans
hlw49
It will eventually seek it own level and quit leaking.
