Husq 128LD edger wont start...
BrooklynBravest
Randomly my 128LD which is a couple years old started to bog down when cutting. Then it just wouldn't run.
Bought a new carb, installed it along with fuel line, filter and spark plug.
Started, would idle with some tweaking and die if you gave it throttle.
Tweaked the set screws a bit more for the hi/low and idle. Now it wont start at all.
Put new gas in as well, 93 octane.
Im lost :/
Check the muffler for obstruction.
In fact take it right off and have a good look at the piston & bore.
If gouged then it is toss time .
Set the carb back to the original settings and try to start without the muffler ( very loud ).
BrooklynBravest
Looks clean with muffler off.
Won’t start with muffler off either.
Checked the spark plug, it’s firing fine.
Should i just go buy a new one? Doesn’t seem worth hours of time.
BrooklynBravest
Another thing to note is there was a lot of oily buildup on the spark arrestor and muffler in general. I’m guessing that’s just fuel that isn’t igniting from trying to start it 100 times.
