Hi all, this is my first post and my first tractor. I just got it used (engine date 2012) and am trying to tighten things up on it. The steering seems to be loose where the gear plate mates with the steering plate. If I manually pull the front tires together as toe-in as possible, the two plates mate nicely (both gear sector caps are snug, pushing up, on the steering plate in their slots). Then if i toe-out the tires (steering wheel doesn't move) the sector plate is not tight, there is about 3/32" - 4/32 of play. I have photos of this. I don't see any plastic parts in the parts diagram that could have reamed out, so wondering what the best way is to fix this? Do I Just have to tighten sector pivot bolt? I haven't tried that yet because it wasn't simple to get purchase on the top flange nut. The other steering parts downstream to the wheels seem pretty tight (the spindle tabs aren't bent).
Thanks for any advice.
