Huskee Wide Cut GT
shill1329
I have a, i think 2006, Huskee wide cut GT with a 46" deck and the Model # tag is missing. It has a Briggs & Stratton 21 HP motor, Model 407777, Type 0137 E1, Code 991215YG
Can anybody help me to get my Model #
Think about it....The engine is a late 1999 model.. The mower should be a 2000 or 2001 model. And it is a garden tractor[GT] and not a lawn tractor [LT] so the model number will start with 14 and will have a H in it for the 46 deck.
Probably likely a 14AJ848H131 or less likely a 14AJ849H131
shill1329
That's close enough, Thanks!
shill1329
Still not quite the same one, mine has 14 speed, 7 speeds high and 7 speeds low, so the transmission code # should be a 7 not 4, and I wonder if the Styling # is off as, by the picture of mine, it shows a "Wide Cut GT" and is different from the one when I use the code #8. but when I plug these in on the MTD website I get nothing. Any other ideas?
shill1329
