HRX217TDA Only Runs With Choke On
steelgtr
Hi Guys, Picked one up for $25 not running. Put a plug in and lubed the recoil and she runs! But only with the choke on, fast mode is rough and idle dies. Any ideas?
thx
bob
Carbs for those engines are less than $25. I would recommend you save the extra labor and time and just replace the carb.
sgkent
make sure the gas is fresh and check for vacuum leaks, crap in the gas tank blocking the fuel flow. What you are describing is a lack of fuel reaching the cylinder, whether it is a vacuum leak, clogged jet, bad fuel, loose head gasket, or other. With the choke on it pulls in more fuel than it would with the choke off.
steelgtr
Thanks, aftermarket? Do you have a link to one that you like?
thx
bob
I only recommend OEM, from a repair shop if possible.
steelgtr
Should this stay running on idle when I release the "Stop" lever?
steelgtr
steelgtr
What is the purpose of the idle throttle setting if you would not mow with it and can't empty the bag with it?
