Decided to take off blades to get them sharpened this time to try and save some money. I started unscrewing middle crankshaft bolt instead of 2 blade bolts before realizing that wasn't necessary at all (and just wrong). I've bought a torque wrench to reinstall blade bolts once I get blades back to get to recommended 36-43 ft-lb. However, I can't find proper spec for middle crank bolt anywhere.
Any thoughts?
What happens if you over tighten either blade bolts or crank bolt anyways?
Thanks for any and all help.
Any thoughts?
