HRR216K9VKA GCV160LAO won’t start
Chris99m
5 yrs old ran rough last year won’t start this year. Replaced spark plug & Air filter.
Starting fluid works for 5-10 seconds and dies again.
Pulled carb it looks beautiful no build up. Sprayed it all over with cleaner.
Same results
Pulled fuel line & petcock carb to tank all clear sprayed with cleaner. Fuel filter had trapped some sludge sprayed down with cleaner. Reassembled same result shot of starting fluid runs 5-10 seconds and quits. Using brand new premium grade gas.
Ideas??
Cab cleaner actually does not clean a carburettor
Either clean it properly according to the instructions you will find at outdoor power info
or replace it with a certified carb from a mower shop
