HRN216VKAA Transmission Spring Bracket. Where does it go?
Poidog
  • / HRN216VKAA Transmission Spring Bracket. Where does it go?
I even bought the shop manual, and it did not address it.
I have a Honda HRN216VKAA
The self propelled feature stopped working, and when I looked underneath, I could not manually rotate the belt. It seemed to be stuck in the pulley on the transmission.
So I dropped the transmission out, and found a small chip of wood that had wedged itself between the belt and pulley, stopping the belt from moving. I removed it by disassembling the pulley and started putting things back.
But for the life of me, I cannot find where or how the transmission spring bracket goes back in. I can find no recess or hole to insert the bracket in. And the shop manual does not give a clear picture or instruction on how/where it goes. I can’t get the mower back up until I can find out how/where that bracket sits.
When ai dropped the transmission, the bracket just dropped out from somewhere.
Driving me nuts.
A picture of the bracket on a working unit at a better angle would help.
Thanks
mechanic mark
