View attachment 26463Hi,
I have cleaned the carburetor and put new gas in and mower is very hard to start ...once started, it runs great.
I sprayed some starter spray into hole in air cleaner and engine starts first pull..done twiceView attachment 26463....so it seems its not getting gas?
I've read several other threads looking for ideas.... and they center around the choke not all the way closed.
Here is a picture with the choke closed....seems like it could go a little farther but not sure.
Does it seem closed? If so, what would I look at next?
Thanks
model: HRM2153SDA
SN MZBB6422974
there is no way to add a picture....should be simple....but doesn't work....had to take a valid jpg and convert to .png
Thanks
model: HRM2153SDA
SN MZBB6422974
