HRM215 SP Mower Parts
dougand3
A neighbor gave me above. First Honda I've had. I'm checking it over, seeing about parts . Carb is so bad that I want a new one. I input the serial GJAB-6575242 into Honda parts and got "not found". Maybe it's older than 2004. Just searching for HRM215 carb, I see 16100-ZG9-010. Does that seem right? Thanks, Doug
Chris Parman
Do this Doug. Provide me a picture of the Carburetor with all intake off. Also, these Carburetor are very rebuildable if you have Skills and a Ultrasonic cleaner and free time. I rebuild these Commercial grade carburetors often and with great success. You will need to fabricate a slotted screw driver (do some delicate grinding) to successfully take out the Jet, sometimes the Jet can be a fickle bitch. Depending on the GXV140 engine model number for example GXV140 XXXX and the engine VIN being GJAB-6575242 I can better isolate a P/N number for you. Or send it to me and I will rebuilt it for you.
dougand3
Thanks, Chris. I've already had the carb off and USC-ed. Tried unscrewing the jet and went all ham fisted. Buggered it up pretty good. I want to try a new AM carb.
Where do I find GXV140 xxxx #? Here are removal pics.
Chris Parman
Chris Parman
Whats a "AM carb" and what does "USC-ed" mean? You need to be very specific with me :) Anyway, the GXV model number should be on the block somewhere. Good God Sir, clean that F-ing Honda engine ! A clean Engine is a Happy engine. The pictures of the carburetor doesn't reveal anything useful.
dougand3
AfterMarket and UltraSonic Cleaned. I'll check the block. Thanks.
dougand3
No, before cleaning. All I found on block. Must be pre-GCV times.
Chris Parman
After further investigation the Honda carburetor part number you need is P/N 16100-ZG9-M01
