Despite having second thoughts I took the plunge and bought a 20 yr old HRM215 which had a slipping tranny. After I cleaned it up (wow..... love those plastic decks!) it looks and runs (seafoam into the carb) incredibly.... except the tranny. I have adjusted the cable as much as it will go (which is kind of curious.... ) and when the self propelled lever is engaged the cable causes the transmission control arm to travel almost an inch. The drive wheels both seem to click properly so the drift keys are likely good.
The exact problem; when you engage the self propelled it jerks but doesn't move. If you lift the rear end both wheels turn but slowly. I am pretty handy and not opposed to taking the entire thing apart... just hoping for an easier solution. The belt looks good (possibly newer) and has decent tension on it. When the self propel cable is engaged both the belt and the transmission pulley are spinning pretty vigorously. The mower is a work of art and I hate to give up on it despite its age. The fact it looks like it does (Awesome even cleaned up the bag amazingly) is a testimonial to the quality of the build. I cleaned her deeply yesterday and noticed today a clear motor oil like on the bottom of the transmission.... likely leaking a bit. Does that slippage/weakness sound familiar to anyone? Any thoughts very much appreciated. Cheers,
HRM215-GB HXA
MZBB-6324314 gen k2
HRM215-GB HXA
MZBB-6324314 gen k2
