The pulley on the transmission is flopping around. Tried tightening the nut but I believe it is as tight as it will go. Maybe the woodruff key has broken? Or is this more serious and not worth fixing? If I attempt to fix, what is the procedure for removing the transmission? I believe it is a gear transmission (3 speeds).
