HRB216 HXA Handle Stay
hosspapa
The upper bolt that secures the handle stay (left side) has disappeared - leaving my handle loose. I can't see any simple way to access this area and replace the bolt -- as it looks to be inserted from the inside of the plastic housing. It seems like I will need to remove the cover underneath (if I can get it out or swing it out of the way) - and then try and reach way up there and slide the bolt in from the inside? Is this what is needed?
If anyone has the service manual pages outlining how to get this bolt installed -- it would be greatly appreciated.
Thanks.
