Pretty confident I have a leak at my oil pan gasket near the front of the mower.
I was going to first check the torque settings on the oil pan bolts. Is it necessary to remove engine, blade clutch, etc. to access the oil pan bolts? If I have to go through all those steps - I might as well remove the pan and replace the gasket and main shaft bearing.
Any advice would be appreciated. This mower has been a good friend for many many years and I want to keep it running.
Thank you.
Thank you.
