HR215KHMA Stuck in Forward Gear
Stive22
Hello.
I recently received this mower. After replacing the rope, it started up but it’s in gear. And whether running or not, you can’t back up. The wheels don’t go backwards. Any suggestions as to what I can do to at least get it out of gear? It fires go forward faster by moving the handle.
mechanic mark
Remove spark plug boot for SAFETY, place a piece of wood under rear of deck & remove both rear wheels keeping left wheel parts together & same for right side. Inspect all parts for wear & replacement. Soak transmission cable at all points with Penetrating Oil & let sit over night.
Stive22
Thank you. I will certainly try that and report this weekend.
Stive22
So I have taken the wheels off and the brackets to hold the shaft. I have attached a picture where the cable attaches to the transmission. That cable does not move. Can you tell if there should be a wider gap or narrower where the cable attaches to the sorting mechanism? So should I try to close it more or open it more? I’ve sprayed penetrating oil on it and will let it soak. Thanks for your help.
