Digger17315
- Nov 21, 2022
- 1
- 3
Hello and new to the group.
Over the past decade or so, I've collected a few vintage Honda aluminum deck mowers (mostly HRS-21's). I recently grabbed an HR215 SXA (serial number 6025456) in generally good condition. In the process of refurbing the old Honda, I pulled the transmission with the intention of changing oil and checking overall condition.
To say the job was a bear is an understatement. Even with the exploded view, it was a struggle to get it back together. Once reinstalled, I can only get the transmission to operate in 3rd gear (highest speed). I did have to take the shift lever off in order to remove the cable clevis pin and I'm afraid that I may have messed up the orientation on the splined shaft...but not certain. Trying to avoid having to pull it all apart again...would anyone on the site have any idea if anything else inside the gearbox could cause it not to shift or is the problem likely limited to the lever orientation on the splined shaft?
Here is a link to the exploded view: https://www.hondapartsnation.com/oemparts/a/hpe/505ce407f870022d24bdbcc2/transmission
Thank you in advance. I'm generally able to figure out this sort of mechanical complexity, but this has me stumped.
