how to remove fly wheel from a kawasaki 21 hp motor
J jcice1 Forum Newbie Joined Jun 19, 2014 Threads 2 Messages 2 Jun 20, 2014 / how to remove fly wheel from a kawasaki 21 hp motor #1 how to remove fly wheel from a kawasaki 21 hp motor
D dnewton3 Member Joined Apr 10, 2012 Threads 3 Messages 48 Jun 21, 2014 / how to remove fly wheel from a kawasaki 21 hp motor #2 generally typical of about any smalll engine. Remove the blower housing and any attachements thereto Remove the retaining nut Use a flywheel puller There is a link to the Kaw small engine shop manual here for the FH series, but I susepct they are all very similar. http://www.parish-supply.com/documents/574.pdf That should be enough to get you where you want to be.
