How to Push Exmark Zero Turn
Chapman
I've got an older Exmark Zero Turn and I'm having issues getting it started, put in new starter and battery, checked the fuses but it still won't start, so I decided to take it to an expert, only problem is I can't get it to move, is there a way to manually push this, I've heard you have to release the hydraulics or something like that but can't find anything else on that, any help would be greatly appreciated, thanks
Hammermechanicman
Need to know what hydros it has. Look in owners manual. Ahould have instructions to open the bypass(s)so you can move it.
Affordable in Indy
Get your belly down on the ground, behind the rear wheels and look for a rod that pulls out. If you don't see one, look in front of the rear wheels. Gonna have to get down and dirty if you don't know what you're doing. You'll find it.
