How to clear dash light and what does it mean.
overdriv
2003 X485 has a light on the dash that looks like a open book with a wrench laid on it.
What does it mean and how do I clear it?
Thanks!
Scrubcadet10
Moderator
Staff member
Probably means to check your manual for a scheduled hourly maintenance.
If it is a service reminder, they are programmed into the timing chip and will come on at every service schedule , hang around for about 2 mowing hours then go away
D
Deleted member 97405
Guest
On older models, there was a yellow switch under the dash that you could reach in and press that would reset the light. It's on the side where you remove the radiator screen. Locate the switch. Turn key on. Press and hold switch until the service light flashes a few times. That should reset it.
