So I picked up this machine and when I prime it, it will start and then die, unless I keep priming. I have been through the carb 3 times. I have cleaned carbs before. I note that the two plastic plugs that cover the holes where you stick the screw driver to screw in the screws that mount the carburetor - are missing. I feel it is taking in too much air. Isn't that why they have the plugs? The plugs are part number 611545, see highlighted part below. I am going to try and rig
up some temporary plugs and see if that resolves my issue. Thanks for any hints.
