How do I remove steering wheel on 180
TFG
Hello, need to replace the steering wheel on my 180 and cant seem to budge it. I removed the thin bolt going thru shaft and am stuck...any advice?
Frog
I used a can of blaster to get the one off my old 185, but WD-40 or the like shoud do just fine. Let it soak for a while and give it some light tapping. Just be patient. I think mine would have stayed on without that bolt..:thumbsup:
Frog
TFG
Tried that and wont budge at all. guy at john deere said good luck when i picked up new steering wheel. thinking about torching the shaft and trying that?
Frog
Neighbor just gave me an Idea, I went out and got my tie rod fork and it fits under the wheel, I suppose if one would hit it with a hammer,it may help drive it off the shaft. Really I dont know why it would need that bolt. Cripes!! Every wheel Ive had to remove has been that way. At least the Deere ones. Maybe the Govt made em use some kind of invisible,undetectable glue??:eek:
Frog
TFG
Still looking for ideas...Not gonna let it beat me!
hondamike
Did you manage to get it off? I'm in same boat as you right now!
Mike
