A friend of mine is sharpening the blade from my Craftsman walk-behind. I asked him to check the alignment also, and he looked at me as if I had two heads. He said, "Do you mean the balance? Because I check the balance by rotating it on a peg when done and take off more from one side if I have to". I said no, I mean to check if the blade is flat and level, so that it cuts evenly. I could not make him understand what I meant, but maybe it's because I am worrying about something that doesn't matter. Doesn't a bent blade cause a poor cut?
